If you use LEDS in your brake light, make sure to wire in a resistor. The cruise control is grounded thru the taillights and changing to a low resistance LED will cancel your cruise (GM used that system in the late 80's). You'll need resistors as well if change out the turn signals. They will flash fast like a burnt out bulb if not.
mmm did not know that, well that seem to be more costly than i will anticipate....
i Think i want to mainly do the reverse light, so they can be brighter when i reverse. do you know if i have to do anything if i just do the reverse lights?
I bought all the LED's to do my all my tail lights. Cost me 30$.
I got some resistors installed in the front to avoid having the crazy flashing lights.
Take a look at my build thread, I have a list of the parts needed!
