- MP5T / 944
Here, Get some of these...
KySpeed said:Heres what ive found best from G-Tech / Strip
I drop my tires down to about 25psi
on the strip i roll into the water put the car in 2nd pull the ebrake and dump it around 5 and hold for about 5 seconds.. enough time for me to walk the wheel a turn to the left and a turn to the right.. i then let the ebrake down and spin the water off.. out of the hole i like to go about 4000 on the strip and somewhere around 3500-4000 on the street i will drop the clutch tach it out.. let back out on the throttle for a split second.. dip back into it and grab second.
HorsepowerFreak said:What kind of 60' times do you run then? You are doing this 5 second burnout on street tires?![]()
97Protegedx said:It was at a stop light. I prefer racing from a roll, but the guy was a b**** and didnt want to . And my tires and Dunlop Graspic DS2.
JDM Sam said:boost leak
Slowp0ke said:i have a problem with the way i launch the car dies for a second i loose all power and then it kicks right back in... what is it and how can i kill it?
example:
im at the drag strip... staged i hold it to 3k .. i slipped the clutch ... (.046 rt) but i spun a little and then the car fell on its face... did i flood the motor? did i get to much traction? with the mods i have it should be higher then a 15.7 @ 93
so help me please
Slowp0ke said:i dont think thats the problem cause i have a boost gauge and it reads fine... the whole car dies for a few seconds no power or anything even my turbo timer counts down then it kicks back over and away i go (uhm)
if i didnt have this problem with the .046 r/t and the trap speed of 93 what time should i see?
KySpeed said:4-4.5k.. or bust .. Spinning is faster than bogging.
HorsepowerFreak said:Yeah, 15.7? That is WAAAY too high.
Do you have a boost gauge?
