Laser Blue Protege5 Build
Nice find. 👍
Junk yards for me were a form of getting away from all the hassles of life and treasure finding.
So many ideas crept into your head if this would work, that would fit, and discovering something new for something custom on your ride.
I'll hopefully have a chance to go next time I'm home but seeing anything for the Protege will probably be impossible. 😕
As a truck driver covering the 48 states I may see one in a couple of months on the roads so finding one in the local junk yard will most likely be futile. 🤷🏼‍♂️
But it's the adventure of doing so. 😁
Keep us informed on the 626 calipers and that project you're working on. 👍
Nice find. 👍
@misnblu. There are 2 currently in Phoenix area yards, 1 each in PullNSave yards in Gilbert and South Phoenix. Was going to make the drive (3 hours), but not this weekend. They both got in their respective yards in Nov 2025 and both have cold air intakes and other goodies, like maybe the factory foglights it appears. One of them has aftermarket rims, but can't tell what size. If you're going through there, maybe you might want to stop by.
I might have screwed up. The calipers I got at the yard were from a 2.0 626, not a V6. They look the same as the ones currently on the P5. It is the same car I got the valve cover off of, which doesnt look any different either. Unless the spark plug holes are different diameter, I am not sure what it does for me for a coil on plug conversion. I haven't actually taken the wheel and current caliper off to determine for certain, but I have a sinking feeling I have gained nothing with the salvage yard finds.
You wanting to rid yourself of coil on plug to external coils with actual wires or the opposite?
Calipers may be the same but banjo bolt may be in another location so look for that.
I know the Kia Rio and Accwnt are basically the same but brake calipers fit with the only differences being the location for the banjo bolts on the caliper.
You have the 1.8 or the 2.0?
Keep us posted. 👍
@misnblu I wanted to go do the coil on plug conversion as in the attached. Also, I read that the 626 calipers bolt on the front, but allow for the larger 626 rotors. But these calipers seem like they might be the same. However, when I search for 626 calipers online, I am never asked to specify V6 model. I am pulling a front wheel tomorrow to compare them to what is on the car.
Keep us posted. 👍
Oh, I have the 2.0
@Coredawg
I see what you're doing and hate to infiltrate this thread with my ignorance of what you have but since you do have the 2 liter motor you must then have this same setup below from OEM factory for your car, yes?
If this is the case then you're using actual coil over plug system for one coil per actual plug.
I see the connectors for the plugs in your picture.
Are you planning on changing the ignition wiring harness to accommodate the would be coil over plug setup?
I've seen posts on other Mazda forums where they've taken coil setups from earlies generation Protege models and run spark plug wires from externally mounted coils.
This has my curiosity up as I had a Chevy Z24 with an OEM coil over that was prone to heat soaking the coils causing weak spark and firing issues.
I made my own external coil pack setup with spark plug wires to the plugs giving increased spark, larger plug gap, and dyno proven more power.
This became all the rage on the j-body.org forums in short time so now you know why I'm asking about your setup.
Thanks 👍
