I have KW V1 coilovers and I was wondering if anyone has their helper springs located on top of the main spring directly under the strut bearing?
I ask because I think the perch between the helper spring and the main spring is interfereing with the top portion of the threated shock body. I hear light clunking from the drivers side when I am driving at low speeds and I hit light bumps.
To date I have replaced the front sway bar bushings, Front end links, and drivers side LCA Ball joint. With all of that, the noise is still there.
Is it possible to relocate the helper spring?
