just a heads up, this computer is designed to encounter knock. when driving on the highway its typical to see up to 6*. when this happens do not let off the gas. The computer is purposely leaning out and advancing timing to the point that it experiences KR. it will count down back to 0. this is critical as the ecu is using this to "learn" the best timing. if you let up it will keep doing this in an attempt to learn the right timing. after a few times it becomes very infrequent. .3-.7 is typical and shouldnt be worried about. anything below 1.0 at WOT is ok as well.
