bobby0283 said:You have to reprogram each window. Using the switch on the door for each window, roll it down slightly, and then roll it up and hold it until you hear a couple of clicks (2 sec or so). That should reactivate it.
Every time you disconnect the battery, you have to remind the windows what they are supposed to do.
mr_sheldo said:Thanks, I will give it a try. These mazda windows have a mind of their own. At least it is quick and easy to fix.
