wickedjra said:what 'exactly' is too hot? i take turns harder than i would normally with any other car because are car is "supposed" to handle them well. do you know more so how fast he was going? was it a full 90* turn? basically, am i going to end up in the same place if i keep up my practices.
ONRAILS said:I guess "too hot" means he lost control. I guess it is possible to lose control at different speeds. He did mentioned that his rotors were warped, and that the abs kicked in. Not sure if that had anything to do with it.
Kevin is a friend of ours here in Charlotte, he doesn't post on the forums though.
Uturnman said:I hope he's not hurt. The car can be replaced, he can't. Be carefull on the road guys.
ONRAILS said:Hey Uturnman... yep, he is ok.
BLU BY U said:do you mine devon or kevin I know devin but no kevin!!! glad to here his fine!
brealmp3 said:was kevin in the speed with the c/f hood and 18's? or have i not met him?
