kartboy shifter bushings?
get bushings !!!!! they somewhat stiffen the throw, so if your shifter had a soft throw, it makes it a little cleaner each time you put it into gear.
the bushings help with the stock shifter and make it more fun and are a must have if you get a short shifter
xtoofast4youx said:
alright thanks alot...is the installation easy?
its easy if you dont have to remove the heatshield like I did to get the brace off. its right at the front of the car though so its pretty roomy down there when up on ramps
i would say it took me less than 10 min to install...
its really easy...
they change the shift feel a lot..
youll love the bushing
