The filter part is much thinner. It will work just fine. The exterior rubber is the same as oem.OUCHABABY said:I just installed a 22-2293 in my 2.3 mazda 3 5 door. I noticed that it was much shallower than OEM. THe outside fit was correct. Am I ok here?
Vic
I installed a K&N last week in 2.0 Mazda3, it is about half the thickness of OE filter. So you probably have the correct part.OUCHABABY said:I just installed a 22-2293 in my 2.3 mazda 3 5 door. I noticed that it was much shallower than OEM. THe outside fit was correct. Am I ok here?
Vic
