I've used K&N in my last few vehicles. There was a slight improvement, but not significant. The advantage with air flow is that they eliminate any possible weak link at the filter for flow restriction. The CX9 has a good sized filter, so I doubt there is much reduction in flow even with a paper filter.
The real advantage, though, is that you don't slowly lose performance as the filter gets dirty, like you do with a paper filter as it fills with dirt.
My cars are just as perky right before I clean the filter as they are right after.
Lindyrect is correct. It's virtually impossible to over oil a K&N. The membrane will only hold so much oil. Any excess oil simply won't stick. The only way to have too much is to hold the filter flat, spray it until it's drenched, and immediately put it in the air box. If the oil side is up, it will choke the air flow until is can be sucked through the filter. If it's down, the extra oil will run off and end up in the engine. Again, you'd have to do it deliberately.
