I got one of those genysis techforce scanners that will tell everything there is to know about the engines data that the ecu see's. I had a problem with sputtering alot in the past, but every sense i installed colder plugs and ran a tight gap the sputtering went away!! or at least at 18psi anyways. Now i was thinking of turning up the boost slightly more and data logging every engine function to see exactly why it might cut out. Everyone in the past swore that it was fuel cut causing the sputtering, yet my car ran rich as hell even with the sputtering problem. and just by changing the plugs and running a shorter gap the sputtering went away, so that alone pretty much proves that it wasnt running out of fuel in my case, in fact i think the reason it was sputtering was because it was dumping too much fuel in causing intermittent spark plug blow out. If only i had the scanner then! My question to the tunning gurus is what parameters should i be looking at while doing my data log?? im thinking, rpm, boost, timing, injector duty cycle and pulse width, fuel pressure before and after the CDFP any others i should map out?? and once i figure out to upload the results from the scanner i can post them for all to see. Thanks.
