Just installed turbosmart bov. I have some questions.
itsamazda!
2010 Mazdaspeed3
So i just installed my bov from turbosmart, its the dual port. I have my corksport sri and turbo inlet tube on order. Is it okay to run this on my car with everything else stock? I know it may sound like a dumb question but I am just curious. Just for info, i have a 2010 speed3. Any pointers or advice? And how do i find the perfect setting for the spring? I read through all the directions directly from their website but i'm just inquiring in case someone has some more advice and or experience!
Thanks!
If your only mods and are the Turbosmart (and if you are running it in recirc mode or 50/50 hybrid mode) and a Corksport SRI and TIP, then you should be OK.
If you go any further, especially if you get a Downpipe and or Test Pipe/2nd Cat Delete, you will need to get CDFP Fuel Pump Internals and a COBB AP before you get the other upgrades to ensure that your CDFP fuel pressure will not drop below 1600 PSI at WOT.
If you want to run the Turbosmart in Vent To Atmosphere Mode, you will need to get a Stratified Gaurdian Angel with VTA software to eliminate leak at idle and low RPM's and to avoid running rich when shifting.
Your in Wildomar? Why don't you go to the SoCal NATOR weekend BBQ? It is going to take place in Wildomar tommorrow.
This is absolutely fine. You might experience some popping from the exhaust but not a big deal. You can throw this on without worries. Just make sure it's bolted on tight so no boost leaks.
dont bolt on too tight either u could break the bolts, also yes upgrade your HPFP and like soon please please!!! the exhaust does pop sometimes between shifts but its kinda grown on me :)
