Just because
69RMSP
MSP
Alright. I suppose knowone esle is, so i'll get the ball rolling. This thread is all about how much psi your running and what supporting mods you have.
I'll start
aem cai
begi fmic
all @ 7 psi /w no boost controller
AEM Cai
Greddy Custom Front Mount
AEM Wideband, custom tune
Boost Controller
Turboback exhaust
3" Downpipe
12-13 pds..(Never boost that high when I'm driving..)
Underdrive pulley
Blitz Blow off Valve
Ha ok. heres everything.. To lazy to rewrite it so copy and paste can be my buddy.
Performance: GHL Turboback, MAM Exhaust Manifold, Injen Cold Air Intake, Turbohoses Hardpipes, Turbohoses SMIC, Apexi Turbo Timer, HKS SSQV, ATP 6psi WGA (holds 8psi), AWR Front Motor Mount, ACT Street/Strip Clutch, Denso Iridium IK22s, Tein S-Tech Springs, Rotorworks Slotted Rotors, Hawk HPS Pads, Corksport Front Strut Bar, Kartboy Shifter Bushings and Knob, Toyo Proxes 4, Autometer Phantom Boost Gauge, AEM UEGO Wideband, Blue Corbeau CR1s
Appearance: DGM Front Lip, Streetglow LED Underglow, DGM Carbon Fiber Grill, Gemini Composites Reverse Cowl Carbon Fiber Hood, 17" American Racing Casino Wheels, 15% Window Tint, Debadged Trunk Lid, Custom Audio/Video
2002 pure white protege es
spool stage 2 tubular manifold with tial 38mm external wastegate, custom downpipe by shoremotorsports (www.shoremotorsports.com) , custom intake by me, custom blow down tube by me, hot and cold ic pipes, johnny race car front mount intercooler, greddy type rs bov, garrett t3 turbo, mpi with two extra injectors, FM voltage clamp, GM 3 BAR map sensor, jspec intake cam, mazdaspeed exhaust cam, spec lightweight flywheel, spec stage 2 clutch, stainless steel clutch line, Mental Addiction Motorsports catless midpipe, sr motorsports cat back exhaust, twm short shifter, awr front motormount, turbo xs high performance boost controller, ported and polished intake mani minus the vtcs, throttle body coolant bypass mod, 9psi kooldino tuned!
as of now, im spiking 11 and holding between 9 and 9.5 psi!
not a msp, but i am holding at 7-8psi, with the wagner turbo kit
voltage clamp
12:1 FPR
Walbro Fuel pump
Turboxs Type H Bov
Custom FMIC
GHL full turboback
Hi boost FMIC
Greddy type s bov
AEM CAI
DSM AFC
ATP 6 PSI WGA holding at 6 lbs and running great.
I can't my car car to boost more then 7 or else the spike is 11 lbs plus.
Talk to DSM Convert but im pretty sure you should still be good. Do you have a windband to monitor your a/f?
Drumfreak said:
GHL full turboback
Hi boost FMIC
Greddy type s bov
AEM CAI
DSM AFC
injen cold air made to sri , hard pipes n fmic , hks blow off , 7 psi ...... tyrin to get a thermal muffler and do custom 3 inch exhuast! with apexi boost controller n run 10 psi buts thats still in progress!!
mods in sig + unichip spiking 14-15lbs and holding 10-11lbs or spiking 10-12lbs and holding right under 9lbs. my unichip boost always varies, even under simililar gear/rpm/load/temp conditions. I always freak when I see the 1bar spike
If I were you id get that thing tuned :P and if you cant do that id suggest you sell it and grab a mpi or afc. otherwise get a J&S knock detector
QUOTE=ZenProtege]mods in sig + unichip spiking 14-15lbs and holding 10-11lbs or spiking 10-12lbs and holding right under 9lbs. my unichip boost always varies, even under simililar gear/rpm/load/temp conditions. I always freak when I see the 1bar spike[/QUOTE]
I do have the AEM wideband but not installed yet. I actually put a softer spring in my mbc and with a spike of no more than 11 maybe 12 at times I see about 8.5 to 9 lbs in 2nd and 3rd gears and nearly 10 lbs in 4th. It's scary how quick the car is now. I'm worried it's gonna blow cuz it feels so damn fast. What ya'll think. Should I worry with that sort of boosting?
