Joep fdc install help
Kidplay11
Mazdaspeed protege
Can someone install thes before and how ? B cable singnal to ecu or to the maf? Wich one is the b terminal on the maf ?pic is someone have pliz
thanks
I hooked mine to the MAf -b signal "green wire" and got a lean check engine code same day... So I immediately took it off and gave up on it because I have no Wideband
