JL Audio Stealthbox
After some time the product is in production & using my car a test bed. Its done. Check it out and sound like I have two twelves in the trunk .Sick Bass (blarf) Running a Jl A1400 mono block.
http://mobile.jlaudio.com/products_stealthbox_make.php?make_id=67&model_id=843
cool looking unit, but please....
two twelves? you lose credibility when you say things like that. i see that and instantly discount anything else you say. one 10 in a stealth box is FIRST to be stealth, and second to sound optimum for that woofer. they did the best they could.
JL stealthboxes are always too pricey, but in their defence they actually spend quite a bit of R&D on each one to make it sound as good as possible. I just wish they'd sell it unloaded, a W3v3 would not be my first choice for a sub.
Yes, but also keep in mind that the stealth boxes are designed for a specific sub. While you CAN find other subs that would work in that volume, JL audio wouldn't want people buying their box, putting a badly chosen sub into it, and then claiming that the stealthbox sounded bad...
all for 750 dollars? unless i found the wrong thing somewher.
thats so expensive!
That's what I found, too. It's bound to be cheaper after a little while, but it's still going to be up there.
Plus you have to add the cost of the amp, and now you're at $1k or more. And your floor is up to 5 inches higher. And you have holes going through your chassis, if you follow the instructions to the letter (unless you just plop it in there).
I'll pass...
that is pretty cool, but what about the other one that goes where the jack is.. cheaper but smaller sub spot..
i really really like it. I have a W3v3 in my JL power wedge and it hits pretty hard from the hatch. Dont know about that 750 price tag though...sheesh. really nice how its hidden, I want it.
Hey, that's what you get when you search. Don't blame me, blame everyone that says, 'SEARCH BEFORE YOU POST.'
