jdm engine question
MI_KE said:
how did you know that ... ?!? thanks a lot i'll trust you
he's smart, sometimes a smart-@ss - but you have to listen to him, he knows his crap
now what should i do with this ssss!! sold it, take the intake on... ??!?!
i've a 1999 626 2.0
d'hoo
yep
well considering there's not too much difference between this engine and your original one, this makes for an easy swap... all you got to do is swap the crank pulley of course, the intake manifold is the only major difference... the vacuum lines are different and you may have to do some work to them... it's really up to you whether you want to use that intake manifold or your original one... if you use your original one, it's a no brainer installation, and you can get some of your money back by selling that JDM one to someone here who has an MSP to see how well this one works
Yes!! is an JDM FS-DE 2.0 and the manifold should work fine on the MSP I had this manifold and I sold it to another forum member! On your car you shoul see a little benefit from this manifold and the intake cam that comes with it!!
Thanks all for your help! I'll try changing the IM and maybe buy mazdaspeed camshaft set to gain a littlebit of some hp!!!
the camshaft on a USA protege and USA mazdaspeed protege are the same.
