Just to keep this updated for future reference in case someone else has problems.
So Saturday morning rolls by and I've got to run to the PO real quick to mail something off. Everything seems just perfect with the exception the CEL is still on. Well sitting at a stoplight all is fine when I notice the AFR creeping up lean again to roughly 16:1 where it stays for about a second or two before returning to normal. No hiccup or anything, just a random lean spot. So I got to the PO parking lot and let it idle for a little bit and it did it one more time, same deal. I don't get it - the idle was fine for two days and now it was acting up. Well I go to an Advance Auto and sure enough it's P0171. Had the code cleared and drove along on my merry (not so much) way. Anyway, everything seemed fine after that. No lean idles or anything. Afterwards I decided to clean the air filter because it had been a while and maybe a dirty air filter was causing something (grasping at this point). Well reinstalled a clean(er) air filter and started her up to take for a drive. After fully warmed up I immediately noticed a slightly smoother idle. That was yesterday and I've driven about 50 miles since and the idle is still smoother and no lean spots as of yet. Guess I need to gie it a few more days to see if another CEL will pop up.
Oh yeah, I also tweaked some values in my AFC to see if I could make some out-of-boost AFRs slightly richer. Didn't seem to have any effect (AFC takes over at 1 psi anyway, but I was told it works slightly all over) but then again the idle is more stable now.
