two questions>theory
check the tube that connects to the back of your valve cover that goes to the intake tube
if it has oil in it as does your turbo (in posted pics)
you are getting excessive blow by and may have an engine issue
If that is the case, I'd do a compression test and leak down on your cylinders
I have a small K&N filter on my valve cover and it had zero oil accumulation
theory 2 - if the valve cover to intake tube is dry. Your turbo seals are shot on the compressor side and is leaking into your intake tract
here is what whoosh told me:
checked my crankcase vent that connects to the intake and there is no oil in the intake path so it has to be coming strictly from the turbo.
just because it is still making boost doesn't mean that it isn't blown... if you bust an oil seal and are getting a signifigant amount of oil on the compressor (cold) side than that would be considered blown. i mean i have 30,000 on my car right now and i have never seen blow-by like that or on anyother car for that matter so just take it in for a check-up mang.
