I've got the full PG intake set up plus a Forge BPV and I used the Cobb AP to put it to Stage 1+. I've noticed that when I let off the gas, it does make that distinctive CLANG noise (which I love, by the way) but it also makes a slight knock sound or a chuff. I was running the yellow spring plus two shims but it was leaking boost so I switched to the blue spring. Do you all experience this too? All my fittings are tight so I know I'm not leaking any boost.
Also, this set up is so incredibly loud. I sound like a damn semi truck when I get on it
