Unhook you vac line to the WGA and blow into it. If you can blow air into it its bad.
what vac line would this be?
The one going to your WGA. Obviously pull the other end of it and blow into it.
ok ill try that tomorrow, what end would i blow into?
Is it really violent? if its not you might be blowing spark out. if its more like a bababababaa but if it feels like you hit a brick wall then its fuel cut.
Change the spark plugs, my car only had 50k miles on it and i was blowing out spark. If i were you thats what i would do is change the plugs and then see whats up after that. They are cheap anyways.
What boost are you running?
Stock-8 psi then run stock plugs
8+ i would go with a step colder.
wastegate actuator=wga
Change them, they are cheap and if they werent bad oh well you are out 8 bucks
