Is it my MAF Sensor?
MazdaDriver9
2013 Mazda CX-5 Touring
2016.5 Mazda CX-5 GT
I've seen similar post, but, my codes don't exactly match. So, I was driving my 2013 CX-5 (approx 50k miles) with no known issues when all of the sudden I felt a thump, bang and almost stalling. Solid CEL, TCS and TPMS lights came on. Car bucked and tried to stall on acceleration even after a restart. On the third restart, car drove 3 miles without issue. I bought an OBD scanner. Can anyone give me input on what this is telling me? I'm hoping the MAF sensor that I ordered will be the fix. Am I on the right track? Thank you!
OBD-IIOBD-II
DTCs: 8
P0102 [0x0102]
Mass air flow (MAF) sensor/volume air flow (VAF) sensor - low input
Status: Confirmed
P061B [0x061B]
Engine control module (ECM), torque calculation - performance problem
Status: Confirmed
P0102(00) [0x010200]
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
P061B(00) [0x061B00]
U0442(00) [0xC44200]
Invalid data received from ECM/PCM B
P013A(00) [0x013A00] Archive (inactive)
Heated oxygen sensor (HO2S) 2, bank 1 - slow response rich to lean
Status: Test failed since last DTC clear, Test not completed during this operation cycle
P0303(00) [0x030300] Archive (inactive)
Cylinder 3 - misfire detected
P0571(00) [0x057100] Archive (inactive)
Cruise control/brake switch A - circuit malfunction
Engine control unitEngine control unit
DTCs: 5
Transmission control unitTransmission control unit
DTCs: 1
ABS control unitABS control unit
DTCs: 2
C0089(64) [0x408964] Archive (inactive)
TCS Disable Switch
Status: Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
U0401(00) [0xC40100]
Invalid data received - engine control module (ECM)
Status: Test failed, Test failed (current drive cycle), Confirmed, Test failed since last DTC clear
I had to laugh when I read this. I had a '13 (sold it 6 years ago to downsize to a Mazda 3) that threw the same code right at about 50k miles. All the histrionics you describe with the dash lights and drivability problems is what' known as "limp home mode". It's the ECU's way of preventing serious damage to the engine. For starters, you don't just start throwing parts at the problem when something like this happens. MAF sensors get dirty over time and the proper response is to clean them along with the throttle body with (wait for it!) MAF cleaner. If and only if that fails to solve the problem should you replace the sensor.
Upvote 0
Thank you for the reply and the confirmation that a 50k can already have these issues. I was planning to pick up some MAF cleaner but to yes, to go ahead and replace if cleaning improves the issue. I'll grab the throttle body cleaner as well, ty. Being the first time I'm reading and interpreting error codes, I wanted to make sure that I'm on the right track.
Upvote 0
If you do change the MAF sensor you might want to avoid cheap aftermarket chain store sensor. OEM Mazda is no doubt pricey but I'm not aware of another quality brand. Anybody know of any.
Upvote 0
Thank you! I did order an OEM that arrives today.
Upvote 0
@paris1 suggested to clean your existing MAF first, and see if that helps.
Also, I am seeing a whole bunch of errors which are very unlikely to be related to the MAF.
1. clean your maf. if that doesnt resolve the maf related codes
2. replace your maf
3. reset codes, see what comes back .
Upvote 0
All of those other codes, Cylinder 3, ECM, ABS, cruise control, etc., make this sound like one of those 'bad battery' issues.
How old is the battery?
Upvote 0
I purchased that twin pack kit. Just the right size for a one, maybe two-use application.
Upvote 0
OBD-IIOBD-II
DTCs: 8
P0102 [0x0102]
Status: Confirmed
P061B [0x061B]
Status: Confirmed
DTCs: 5
DTCs: 1
DTCs: 2
TCS Disable Switch
Do yourself a huge favor buy the OEM at any of the auto zone stores they all are crap. I just had one replaced and had to have my pcm updated no more issues Ya!
2014 cX-5 sport just turned 200k
Upvote 0
It's funny how one trouble code can light up your dash like a Christmas tree with multiple other alerts tied on.
Modern vehicles should have the throttle body and MAF cleaned every 50K miles. It's unspoken rule for proper maintenance.
Glad you got it sorted out MazdaDriver9.
Upvote 0
I'm almost certain I nuked my MAF when I tried cleaning my intake valves using CRC Intake valve cleaner. I had sprayed into the intake just after the MAF but I think it splatter back some, fing straw got pinched. Im at almost 70K on my 2018 CX9 yes she's a mileage baby, but she does build up carbon. Had to clean my EGR not too long ago. Anyways, my throttle is open at idle about 12% my LTFT is an unpleasant 10 to 11%, my CAT is not loving it. So, I removed the throttle body and did a deep clean. My throttle position didn't change much but as I watched my realtime values I started noticing my MAF g/s drift alot and dip below 2.0 with an immediate spike in STFT. I don't think I have any vacuum leaks (steady at 20 to 21). Tried cleaning MAF, no change. New MAF comes tomorrow,.crossing fingers, CATS ain't cheap
Upvote 0
