Evo Scooter said:You can use it if you want but it's reallly a waste to pay for what you don't really need. These cars are tuned for 91. If your car had an aggressive tune or you had raised the boost then you would need the 99. If your car is stock don't waste your money.
desperado-c said:I don't think it's so cut and dried. A guy who posted on the Mazda Three Forums as Mazda_Tech claiming to be an MNAO product dev engineer for the MS3 said that the jump from 91 to 93 is good for a couple degrees of timing advance and a couple of extra hp. So the question is at what octane will the MS3 ECU cease to advance timing when no knock is detected? The Euro Focus ST will produce 8% more power when running the UK equivalent of 96-97 octane in the US over what it puts out with the equivalent of 92-93 octane. Maybe the MS3 has the same capability.
using higher octane gas dosen't directly harm the engine, no.. but it does increase the rate of carbon build up which can bog performance. To answer the orginal question though, no it's not bad but it's not going to do anything and just cause more gunk build-up which isn't exactly desirable.Mocoso said:And Ive never heard of higher octane gas causing damage or lowering performance on any car.. its just a waste of money for engines that cant make use of the higher octane (such as low compression engines)- I suspect if "racing fuel" clogged sensors etc. it was due to the lack of detergents and "low quality" storage rather than the octane rating...
the euro focus ST is also designed from the get-go to take advantage of higher octane fuels, even economy corolla's and civics over there are programed for the equivilent of US 91+ octane gas.The Euro Focus ST will produce 8% more power when running the UK equivalent of 96-97 octane in the US over what it puts out with the equivalent of 92-93 octane.
sephiroth said:using higher octane gas dosen't directly harm the engine, no.. but it does increase the rate of carbon build up which can bog performance. To answer the orginal question though, no it's not bad but it's not going to do anything and just cause more gunk build-up which isn't exactly desirable.
Mocoso said:. .... So dion51 there you have it: some of us think its just a waste of money while others think it can actually do more and damage the engine... which ever ones are right either way it is bad for you (actual engine and/or your wallet)
mcb said:MS3 are tuned to work on these high octane... In Australia they use 98 and its the same tune that we have in north america. An other exemple, in japan premium gas is 100 octane. So imo yes you can will have more power with that gas. If you have $$ to try make 3 dyno pulls on 91-93 and 3 pulls on that 99 you will see if the power change.
i'll check on mazda (official) forum to see what moderators will tell.
desperado-c said:Once again, not so cut-and-dried. Since most ECU's now use anti-knock systems to change timing/fuel parameters, OEM tuning of cars for higher than recommended octane is an technique that increases output even on the recommended octane fuel. http://www.bp.com/sectiongenericarticle.do?categoryId=9009565&contentId=7018404. And if a car has an "adaptive engine management system" like the Euro Focus ST, it can apparently take advantage of substantially higher octane. http://www.bp.com/sectiongenericarticle.do?categoryId=9009114&contentId=7016932. There's a ton of info on this on the BP website, as part of their effort to sell their outrageously expensive BP 102 (about 96-97 octane US).
So, does this mean you will get the maximum benefit possible from using straight 99 octane? Highly unlikely. Would you get at least a marginal benefit from mixing in some unleaded 99 octane from a well-known, widely respected, widely distributed company? You definitely will if the resulting mix is 93 octane, to the tune of a couple of hp. And is it possible that you would get a substantial benefit from bringing the mix up to 95-96 octane? It depends on whether the MS3 has an "adaptive engine management system" like it's corporate brother, the Euro Focus ST. If it does, the benefit could be as much as a 7-8% increase in hp.
