- 02 1500 4x4, mp3
i always liked the aeromotive fpr.
Thats a good question, could someone tell me if there is something else that will go wrong with one of the cars sensors?TurfBurn said:I'm a little confused then as I've been under the impression that the reason for the voltage clamp was to prevent fuel cut from the boost. I also have been under the impression the entire time that the voltage clamp is on the MAF signal, which won't effect the car seeing an "overly rich" condition.
Now if it is on the first O2 and is clamping the voltage at about .6 volts or whatever, then it makes plenty of sense. But I would think would have other issues as the OBDII relies on a cycling signal and zero crossings to determine AFR and that things are running as is appropriate. Clamping the signal will not show a a zero crossing and you would STILL get an overly rich condition as far as the ECU is concerned. I suppose you could clamp it below the zero crossing point of .45 volts and then the ECU would think it was lean and try to add fuel and wouldn't think it was too rich... but it would progressively add more fuel in its efforts to push it over the crossing point. So I'm wondering which of the above is the situation here...
