I have been having an intermittent blower motor problem on my 2013 Mazda 5. It started out having to drive a minute or two before it would turn on. Now I can wait 30 minutes plus and it still won't turn on. It usually works when cold but usually won't work when hot. I changed the blower motor resistor and still had the same problem.
I also removed the wind shield cowl under the hood and didn't see anything interfering from the inlet side.
Decided to bring it to the dealer and was figuring $300-500. They told me the repair will be $900 and change. Is that a reasonable estimate to replace the blower motor?
Secondly they also said that the air box had a lot of debris and recommended cleaning that out for another $200.
