ion springs
I've got the pics, just need to have ION post them, as I realized that there are too many and each is quite large...
I keep teasing, but this time, the pics are here, just a matter of ION posting a link to them...
[edit] - I tried sending the pics to ION last night in a zip file, but had some trouble due to the size...22 high res pics = 35 Mb zipped....what I'm going to do is try to make the pictures smaller in size and resolution...just didn't have time for that late last night...
ION - I'll send you a zip file to host when I reduce the size. Cool?
haig - if you can separate them into 2mb zip files just email them to us at -> info@ionperformance.com
That 35MB file is way to big to go via email :D
Or you can use MS Paint to scale the pictures to 50% and then save as .JPG :)
We have space to host them for you :)
Pictures!
Thanks to haig, here are the pics :)
iON Sport Spec front springs vs. OE Front Springs
iON Sport Spec rear springs vs. OE Rear Springs
iON Sport Spec Springs Installed (front view)
iON Sport Spec Springs Installed (side view)
iON Sport Spec Springs Installed (rear view)
iON Sport Spec Springs Front Right Fender Gap
iON Sport Spec Springs Rear Right Fender Gap
these springs work on the msp as well correct? How much do they lower the msp persay? Just curious.
--Bryan
azian6er - yes these springs work on the MSP as well, however the sport spec will be basically the same height maybe a little lower by 0.2" as you are now. The race spec will bring you down ~1.2" from your current height.
azian6er - both the sport spec & race spec are $199US + shipping this is the discounted price for club members. (payment via MO, or add 7% for CC via Paypal)
Springs
I would like the Race spec When will they be available, Please let me know asap I am in the market for some now. Thanks
NCMP3 - the race spec is already available :) we've shipped out 3 sets within the last 2 weeks! :)
Drop us an email if you want to pick up a set :) we've got 2 sets left before we're making another run.
anyone notice the p5 always sorta leans to the drivers side, even on stock springs?
Stealth5 - the picture wasn't taken with the camera parallel to the ground, hence it looks like it leans slightly.
However the vehicle height is slightly lower on the driver's side due to extra weight of the vehicle on this side of the car. The Sport 20 in Japan is slightly lower on our passanger side.
Do these springs only lower the car, or are they stiffer too? Or does the car only handle better (if at all) because of lower center of gravity, since the car is lower?
stepson - it's too bad haig hasn't posted his impressions of the springs yet. The springs are designed both to lower your center of gravity as well as shift F&R balance. They're designed to give more oversteering @ the limit to produce a more neutral handling.
The springs are linear in the front and progressive in the rear, both are higher rates then stock.
Our products are FUNCTION OVER FORM. If it doesn't improve handling, we wouldn't have had them made at all.
stepson - sleep is for the futile! muahhhh :D j/k we like to keep everyone as well informed as possible to minimize mis-information.
