www.cp-e.com
We've been considering making exhaust products for the CX-7 for some time now, and we were finally able to pull the trigger last weekend. The guys had access to a CX-7 so they spent a few days prototyping a dual exhaust. Our goal was to produce one that not only frees up restriction in the exhaust system, but also one that won't drive you nuts when you're cruising! To that end, we utilized two of our highest quality mufflers which happen to be very quiet. They're made in the USA, are hand TIG welded, and look absolutely gorgeous sitting under the CX-7. Anyway, I'll let the pictures speak for themselves:
Now, just to clarify, there are two sections to this exhaust system, and they can be installed independent of each other. There's the test pipe, which runs from the end of the downpipe to the rear muffler section. Then there's the rear muffler section, which can be bolted to the existing stock CX-7 exhaust. So if you're just looking for a better sound, you can simply opt for the muffler section. If you're looking to gain a little more power, then get the full system which replaces the second cat. We don't have any dyno numbers yet, but we'd be surprised if this setup didn't pick up a little power over stock
And sound clips? We've got them, and they're going to blow you away. The sound is so mellow and deep, but far from overwhelming. There's no drone. None. When you're in the car with the windows up you have to struggle to even hear the exhaust! But from the outside, its obvious the CX7 has been modified, and it's all business at wide open throttle. Hang tight and we'll put some sound clips up! (rockon)
