On my other thread, rktktpaul provided some information. Here is the quote "A variable intermittent wiper control lever can be installed to provide fine tuning
of the time interval of the intermittent wiper setting. Unfortunately, no direct "bolt
on" upgrade for the 1st and 2nd generation Proteg's exist. The MX-3 parts will
not work either, since the control hubs are a very different design. The European
spec 1st generation's control switches will fit into the car, but is not electrically
compatible directly. The wiring will have to be extensively modified for the
controls to work. Fortunately, as part of the corporate cost cutting measures,
some of the parts from the MPV, Tribute, and European 626 are interchangable
with the 3rd generation Proteg's. Of those parts, the wiper controls from those
cars can be swapped into the 3rd generation Proteg's. The control lever from
the 97-02 European 626 sedan will fit into all 3rd generation sedans. This part
must be imported from an importer. Only the control lever from the 99+ MPV,
2000+ Tribute, or 97-02 European 626 wagon/hatchback will work with the
Proteg 5 and can be purchased locally. The part numbers are:
GE6M-66-128 variable intermittent wiper lever (from 97-02 Euro 626 sedan)
GE6V-66-128 variable intermittent wiper lever with rear wiper control (from
99+ MPV, 00+ Tribute, 97-02 European 626 wagon/5 door hatchback)"
Hope it helps.
