Interesting electrical item
06 LS MS6
07 BM GT (shell has been struck from the roll)
If you have a LED in the dome, try this
when its dark out, look at your dome, while flicking either rear window switch to the closed position
post back with what your car does
mine illuminates the dome, about 1/10 power, brighter with the driver rear
Not uncommon. The LEDs will respond to way less power than the incandescent. You can put a resistor (100 ohm, I believe) across the leads. It will put enough load to calm the lamp.
