So the ms3 is decently quick until it warms up and stop and go night cruising the intercooler gets so heat soaked the car becomes a lagging pig.. can i halfway fix this still using the stock intercooler?
**** Fmic ****
I have seen this stuff before but where would we put this...There is a heat relective tape that the Subbie owners use. Its gold in color and I've been told it reduces up to 30* of heat...
I'm planning to look into this...though a roll is a little expensive.
Check it out: http://www.pegasusautoracing.com/productselection.asp?Product=1838
So I have also though this through. I have a old 87 rx7 turbo2, back when it was close to stock form, I had a stock top mount, which of course would heat soak, and I never really did anything about it till I went with the fmic (mounted horiziontally to the ground, so not really a fmic, but flows super amazing!) So for my 3, Im not going fmic, too much money, Im trying to keep the car basically stockish, not going to crazy hp. So recently I purchased a spal fan,which Ill be mount on top of the IC. During slow crusing and stop and go ill have a switch on the fan. Fan flows 810cfm so it should work quite well. During long highway drives your IC shouldnt heat soak, as long as you have sufficent airflow. So thats my fix, ill have pics up maybe next week when Im done
