jasonspeed3
Well, first off, I got the BOV from a friend who had it on something else, so I had to get he flange and recirc valve. The first thing I noticed is the flange doesn't seem to be the same shape as the other one, but looks like there are 2 different ones, the CPE that is and the other HKS that isn't. I got the c clamp in and locked it down, but it still kinda spins freely. It won't pop out of the flange cause I tried pulling it out, but I would have thought it would fit tighter. Secondly, the stock clamps on the tubes aren't even close to keep the tubes tightly on the back side small tube and the recirc valve. Is it normal to have to use the tighten down hose clamps, or should these just swap over? I was thinking the nipple on the back of my HKS was smaller or something, but I see several others that are like that. SO, now I have to go to the store and get the hose clamps. SO, 2 concerns are, how do I know if the bov is seated in the flange, and the hose clamps, do you normally have to use them. Thanks!!
