haha just got th4e horn at the auto parts store payed like 18 bucks and now it sounds like my nissan frontier (traded in). funniest part about it i packeged the original mazda hard in the box and returned it. kinda fukced up but w.e...(idhitit)
Reminder to self - Do not sell anything to, or purchase anything from FrancoNemo.
-enganear
I might just go to a junk yard and grab one off something there. The price is right!
Hey guys, I am posting this to help the next guy that wants to change his horn. I don't need to tell you that the M3 Horn is weak...like my son's bicicle!
In any case, I bought a Fiann HWY blaster for aroun $30 and it sound so much better, in fact, sounds like Titan that I traded in for the Mazda 3 !
The thing is that I have to buy a cheap Jack and 2 small supports, one for each front wheel side, because you have to get under the car. Don't even bother to try to find the horn looking from the hood. You have to get under it.
Looking for it, I took off the big plastic cover first, but I did not need to. I should only have taken the one immediatly under the drives headlight. The screws to losen it go around the drives front wheel also. Get a flash light too! It is a tight spot.
It is a one wire installed horn. I thought I would leave the original horn there and just add the Fiann to it, but when I saw how short the little wire was and how much trouble would be to try to split it, I gave up... Took that peace of junk out, and just install the Fiann on its place, that buy the way, looks exactly like the one that come with the car.
Total cost:
1 jack( i will be using it for tire rotations now) $18, 2 support stands $15
and the horn $30(around that, can't remember exatly)
I hope this helps!
David
(rei)Did this just plug in or did you have to modify anything?
I installed one of these last week. I honestly cannot tell much of a difference. Now it just sounds like a stock Chevy horn (probably is). It may be slightly louder but not worth the $20 and 10 minutes I spent on it. I'm going to the Nautilus at some point.
How hard is that one to install?
The Nautalus is a bit more difficult if you want to do it right. It draws enough current that it should have a relay. On mine, I picked up the power as shown in the picture.Step one: lift it up with ur jack or car ramps
Step two: take the three screws under the bumper (drivers side) out.
Step Three: move the black plastic oput of the way
Step Four: Look up and u'll see the horn
Step Five: Un-plug the black clip of the horn
Step Six: unscrew the stock horn of the mount
Step Seven: screw the new horn into the stock mount.
Step Eight: plug in the black clip
Step Nine: Try the new horn (horn will no work if not screwd bc by screwing it it give it a ground)
Step ten: to steps 3-1 again. and done!!!!
(guitar)
good enough?
Seen 'em... like the guy that comes up on unsuspecting pedestrians and blow 'em away w/his train horns.
I don't know, but that seems awfully juvenile to me.
