You can use same ground points and power points. For power just run wiring from either the fuse box, or like I did in my MR2 (different car, but installing in the interior is no different no matter what car you have), take power and illumination wires from the stereo harness and run them down under the steering wheel and over to where the pod will sit. Then just ground it to a metallic point down in the kickpanel behind where the fusebox is.
Best place to take vacuum from is the fuel pressure regulator or the brake booster. Just T into it. Id say Brake booster is best cause its right off the firewall.
