Whats up all? This sat I installed my TEIN SS COILOVERS and i must say they are ******* AMAZING. I have a question for people that own them? what are yours set at? Also some info for those who are going to get them and install. You need to take the whole interior out of the trunk in order to do it. on the rear i needed to take the calipers off because they had the bolt heads going into the brake lines it sucked. Also the rear sway bar was attached with these terrible allen key bolts that rusted to death on there so i had to remove the rear sway bar still attached to the strut so i will be replacing the oem bar with an awr bar with adjustable end links. should be good the drop is awesome you can set it perfect with a little tape measure or count the threads if it wasnt for the back we would have gotten this done in about 2 hours instead it took about 9. but i am happy with the result. PS anyone know good spot to get some awr products besides protege5 online?
Will post some pics asap
