FreeStyLinDrive
Banned
- 2005 Mazda 3s,---------- 05 SL500, 04 SLK350 Benz(s)
Im upgrading my radio antenna base and need to know the type of wire that comes from the stock radio to the antenna inside the roof the car. Could someone explain to me the wiring terminology / process from the back of the stock radio to the antenna on the outside of the car?
My current issue: I ran the Sirius satellite radio wire through the roof opening where the stock radio antenna wire and antenna is mounted. I have a problem with reinstalling the stock radio antenna because the metal connector that is attached to inside of the car has sharp teeth that scrap against the roof. The sharp teeth scrap against the inside roof of the car so that there is a water proof seal. Since the satellite radio antenna wire goes through the mounting hole, I can not tighten the radio antenna base because the teeth will break or scrap against the wire. So I need to install an aftermarket antenna. I just have no clue which one to buy.
I searched the forum and came a crossed a few different things like coax and two different information sources on the net:
1) E-bay: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=7970629010&sspagename=STRK%3AMEWA%3AIT
2) Aftermarket Installer.com page:
http://www.installer.com/antenna/ant.html
When I search on Installer.com page for a Mazda 3 antenna it comes up with
15"38cm black helical wind removable fiberglass mast, 6"-15cm coaxial cable and power supply wire.
Is the wire that comes from the radio to the antenna called coaxial cable and is sized by this term 6-15cm?
From what that website has posted, It seems to me, that the term mast is another name for antenna. I posted a request in the interior and exterior modifications and no one has helped me thus far. I hope one of you people knowledgeable in this area can assist me. I even called Mazda hotline and they did not even know. Any help would be appreciated.
