Inputs on Kenwood Head unit?
Caffeine
Can anyone that has their kenwood unit which is pretty much everyone tell me if it has a line in jack? I have a 20 gig mp3 player that it would be cool to just plug it in rather then burning all that music to cd. I have like 8 gigs so its alot of cds :( . Plus I would have to get a CD RW. Thanks
Here is what it says about its AUX input:
Auxiliary Input "Ready": When used with an optional adapter (KCA-S210A or CA-C1AX) or with the KDC-CX87 CD changer, this unit can accept input from an auxiliary source. This unit cannot accept input from an auxiliary source unless the appropriate adapter or CD changer is purchased and connected. When the CA-C1AX adapter (item 113CAC1AX) is used, you cannot connect a CD changer to the head unit because the CA-C1AX plugs into the DIN changer control connection on the head unit.
Looks like you need this thing:
http://www.justkenwood.co.uk/stock01/auxin.asp
Should do the trick for you.
-Sixmil
