Injen install...
mspdfreak
2006 Mustang GT
My intake comes in early next week, and I was wondering if there are any install problems I need to be aware of? (For some reason, the search option is not working for me.) Thanks.
Installation is easy, it shouldn't take an hour. Just make sure you tighten your clamps well on to the turbo, if not it'll pop off and cause the engine stall. I'm speaking from experience!
Install is a snatch. Follow the directions, the bending the braceket for the coolant requires some custominzation. But other then that it is a snap. Make sure you screw everything nice and tight, and make sure you dont move the splash guard, and screw the fender wall nice and tight.
Try taking the wheel off for more ease in place the fitler on the pipe.
-Eric
before you go and bend the metal piece with the coolant attached to it, make sure it fits without the modification, cause i bent it and then found out it fit on without having to do that. it'll be less time and less destruction of the parts.
