Dexter said:can you explain more how you can find out injector duty cycle via OBDII. that software you linked bill, doesnt work with my scantool. do you have any info on the pid and such?
turboge said:Doesn't work with your ELM tool?
It is just in the software. There is nothing wrong.02p5 said:just an update guys.
When I graphed out the 30 secs of the injector duty cycle I found out that when it did max out to 99.9% it does it when i just slightly press on the gas; on the graph it would show a spike. When I did a WOT start all the way to 4th gear the injectors did not reach any higher than 71% which is perfectly safe.
So my conclusion is my injectors are not maxing out and on the graph it just spikes up and down randomly when I press the gas. Still don't why it does that though...
