Infotainment restarts when starting from accessory mode
Does anyone know if the infotainment should restart / reboot when starting the engine from accessory mode?
The issue is that usually I start in accessory more, so the engine is not on, so that I can set up the maps in Android Auto and the music and then I start the engine. At this point the infotainment system reboots / restarts, so I have to set up everything again from the start.
I wouldn't want to have to set all these up with engine running. Does anyone know if this is normal and if not is there anything I can do to resolve this?
I am worried that the battery might be low and this is why it's rebooting. Shouldn't this always be on when starting from accessory mode?
Thank you in advance for all the help
