Guide Turbocharging and Modifying an Automatic Protege5
Hello, as you may know, I have been interested in turbocharging my automatic since the day I bought it. I feel that the automatic may have more potential than the manual because of its taller gears, torque converter, and ability to stay in the motor's powerband by itself. I have yet to prove this on my own, as I have just started collecting parts for my build.
To turbocharge an automatic, you will need a piggyback ECU like the speeduino to control fuel and spark while the stock ecu controls the shifting as seen in this thread Guide - Run your Mazdaspeed Protege on a Speeduino
Here is a quote from Chris with SpeedyEFI
"When you order your ECU from us, make sure to include in the notes that it's for a piggyback application and we will float the temp sensor inputs.
If you have specific questions about the install, please ask. The speeduino wiki and the forums have decent guides in how to setup a piggyback application, but I know there will be questions that pop up.
here is the wiring diagram for it to run in piggyback.
p-xq3kTb0udwWD6P7qZ3S6f_x94qj8aRmdqXLYP42YY0MQYFIOPtn_-CA6aJ1pIyZMoA0ar3xZvP2f-kYs8NFDzdbdreLthxn-6t3DOS8bgEqW1AyER-QVhg_TIGEDAN4YVhvLoUE8SQMVSn2PyOhUY
and the tuning files are provided here by the author Speeduino Tune Files - Google Drive
as for the turbo system, this thread shows all the parts necessary to complete the swap A Guide to Turbocharging your 2.0L FS
when it comes to the automatic transmission, I have been in contact with lentech automatics. even though they do not produce parts for our transmission anymore, they have been very helpful in identifying flaws in the stock automatic such as the plastic stator, the open differential, the weak 2-4 band, and the lack of cooling capacity. here is a quote from them on how to adress these issues
"The plastic stator is an internal component in the torque converter, so you'd replace the entire torque converter with an upgraded one that has that component upgraded to aluminum.
As for the differential, I visited the website and it does list a solution for the 4F27E
(update: do not buy the LSD. it looks to
be a continuation of the “phantom grip” company’s snake oil. Basically a crappy Detroit locker)
Regarding friction, it’s not just materials (specifically in the 3rd-4th (direct) clutch...its capacity. Some applications use single sided friction setup and others are traditional friction/steel plates alternating. Focus models typically have 3 friction and the steel plates between them are the same thickness as the top pressure plate. An easy upgrade is to order extra steel plates for the forward drum (which are the same pattern and fit into the direct drum too) and stack it like this: thick steel plate against the piston, then a friction, then thin steel plate, friction, thin steel plate, friction, thin steel plate, friction, thick top plate, snap ring. This upgrades it from 3 to 4 friction discs....a 33% increase....all with factory style parts.
Do the upgraded converter, add those extra frictions while doing a rebuild and add a cooler and it should live. Pressure could be added via the valve body, or if you have ECU access, it can be done via tuning as well. Good luck!"
since the stock ecu on this car has never been cracked, tuning the ecu is not an option.
a shift kit to raise line pressure and reduce friction is available here Trans Go SK4F27E: Valve Body Shift Kit 4F27E, FNR5, FN4A-EL, FS5A-EL - JEGS
aftermarket transmission cooler is here https://www.summitracing.com/parts/tci-820500
an electric fan may be necessary to keep the transmission cool in hot weather. Heat is the #1 killer of an automatic transmission
the stock rods should be able to support the power produced by 7 psi of boost. I would go with forged rods and pistons for anything over 190 crank horsepower
the block does not need attention as it was used in a turbo-diesel model overseas, which is where many of the parts for the mazdaspeed protege originated
the FSDE also suffers from oil starvation when the oil moves away from the pickup in the oil pan. An aftermarket baffle can be found here Pope Engineering Performance (PEP) Oil Pan Baffle for Mazda Protege
DO NOT PLUG THE OIL SQUIRTERS!!!! they are necessary for piston cooling especially if you run forged internals!
also, since the turbo will be taking the place of the manifold catalytic converer, you will either need to put another cat in front of the secondary or use a drilled-out spark plug non fouler on the o2 sensor to trick the system if you dont want a permanent CEL.
with all parts accounted for, the system will run around $3000 if you rebuild the transmission yourself which I would not recommend
a lot of other information on the mazda protege can be found here Protegé FAQ
I have yet to put all this information to use in my own vehicle. I will be turbocharging my car this summer and will update as I go. Furthermore, I am not responsible for damages to vehicles. do keep in mind I am a dumb 18 year old and my experience with these cars is middling at best
for transmission control you may be able to use a microsquirt ecu. not sure on if it has been done on this car or if it needs to communicate with the speeduino.
I've had great success with the Speeduino Piggybacked just controlling Fuel and Spark on a MT. The Stock ECU happily goes along thinking it's still running the show. (It even still bumps the IDLE up for AC like stock) I would imagine with an Auto it would continue shifting the Transmission in the same manner. You're almost definitively always going to have a CEL though because you're never going to be able to maintain the AFR that the factory ECU is going to be trying to control (realizing no matter how much it changes the fuel trims there will be no actual AFR change)
I've had great success with the Speeduino Piggybacked just controlling Fuel and Spark on a MT. The Stock ECU happily goes along thinking it's still running the show. (It even still bumps the IDLE up for AC like stock) I would imagine with an Auto it would continue shifting the Transmission in the same manner. You're almost definitively always going to have a CEL though because you're never going to be able to maintain the AFR that the factory ECU is going to trying to control (realizing no matter how much it changes the fuel trims there will be no actual AFR change)
I'll just install a bluetooth code reader and check it often. either that or somehow trick it. I thought our cars only turn on the CEL for misfire, knock, or emissions issues though?
I know for certain it will throw a CEL for lean or rich idle. I haven't checked what codes mine is kicking as I'm not subjected to emissions testing. If emissions is an issue, you could wire the speeduino up like I did where I can flip plugs and switch control back to the stock ECU, for a period before testing. I would rig the wastegate open so it doesn't build boost and drive on the stock ECU for testing.
Luckily Washington got rid of emissions testing a few years back and since the car is coming up on 25 years old even if they brought it back I would be fine.
?? Despite only being a 4 speed the TQ can multiply the torque coming from the engine and put it to the ground. 1st gear is the equivalent of 2nd gear in a manual. It also self learns shifting patterns to stay in the power band at all times. It is a pretty stout little gearbox once the direct clutch issue is fixed and an LSD added
My apologies for summoning this thread from the dead…but as far as the 2-4 band, did you ever find an upgrade for it?
Also, for the forward steels, did you just order them through Mazda?
They still make the valve bodies on request, but they don’t make any other parts for it. I do have some info from them on milling an msp LSD to fit as well
Getting an LSD would be a dream. I actually kind of gave up on that idea as well as the valve body.
You just need to mill down the ends of the diff and clearance the transmission casing a little. Other than that the automatic ring gear will bolt on with no modification
When you say to mill down the ends of the diff, are you referring to shortening the input shaft sleeve on the top of the diff?
