Well - i did mine, i guess al lfor the better- i also called the dealer just now, they told me as long as the 1st oil change is between 3k-5k, there shouldnt be a problem
As for some other issues:
1.My car is still pulling left, they will check alignment when i go in next week
2.The knock i mentioned in a different thread is coming from underneath the dash (either suspension or something else) in the front right area, and from some people in my car i gues sthey can feel some of it when it happens. Its nothing shocking, just sounds like literally a soft knock on a door
3.I told them to flash my ECU due to gas mileage (even tho mine is ok) and see what happens
The tech said that the knock, the pull, and the mpg sound related to a suspension issue, which as a result could cause the pull and whatever else
I'll let you all know next week what goes down!
