I'm guessing the CV joint. Anyone disagree?
2015 CX-5 Grand Touring AWD 2.5, 125k miles
I have around 145k miles (2015 CX-5 GT). In 2024 I had a noise from the front. I did the little protectors on the springs, no luck. I did the LCAs and no luck. Did the sway bar links and that ended up fixing that noise. Note on this, noise didn't happen when sitting in the air, had to jack up the wheel to mimic car weight on it.
This summer I noticed the front left wheel having just a slight wiggle when I rotated my tires. Figured it was the wheel hubs so I replaced both front ones and that seems good so far but then recently I started hearing a clunk/squeaking noise coming from the front left when turning only. Noise sounded just like if you were turning your wheel say on an epoxy floor and the tire is just making a squeaking noise. Wasn't consistent though. Also would notice a squeak once in awhile turning tight turns.
I lifted the front and nothing loose, no noise when turning etc. Put a jack under the LCA to mimic being weighted and then I could reproduce the noise. Spent an hour or so banging around trying to find anything loose. Checked the steering boots and CV joint boot but dumped a bunch of grease when I did that one. Put the wheel back on to test drive it and the noise was worse. If the road was smooth and straight fine, any bumps or turns and loud clunking.
So I'm guessing the CV joint. Anyone disagree? :D
Now I'm wondering where to get one from? I've heard only go with OEM. I've read stay away from Autozone, Napa type ones, but mostly you only hear back from people with issues, how many could be out there with no issues so you never hear from them.
I checked Rockauto but not sure if they are any better. Looks like my choices on there are GSP, Top Notch and Trakmotive.
So anyone have solid proof/numbers to stay away from say Duralast Gold, or O'Reilly's, Napa?
I've had this car since new and have no plans on getting rid of it anytime soon.
Thanks
I would tend to disagree. CV joints usually make noise only when (moving and) turning, when you can get grinding or knocking noises. But I doubt you would hear anything from them while stationary.
From your symptoms I would think the LCA(s). I think you said you replaced them, but check the ball joints again anyway, and make sure all is tight (incl. the inboard bolts)
Should the CV joint have any play? I removed the axle nut, caliper etc and slid the axle out of the hub. When I push on the outer spline in and pull out, there is play inside the boot/cv joint. Could this be the issue and it needs replaced or are they suppose to have a little play?
Ok so I checked the good side and it seems to have the same amount of in/out play.
I put it all back together to do another test drive. What I noticed was grabbing the tire at 12 and 6 o'clock positions there is no play. Grabbing at 3 and 9 it has play or wiggles. The other side doesn't.
So what could that indicate?
Are you saying there's free-play in your wheel?? If grabbing it at 3 and 9 has free-play, yeah.. either tie-rod ends or wheel bearing. Does the noise vary with speed/RPM?
Another way to test CV-joint is to have the steering at full-lock left (or right), and do a figure-8 slowly. If it is the CV joint, you'll hear the CV joint make the.... knocking sound.
Did another test drive. The boot on my outer tie rod end is damaged and will need replaced but it seems solid right now.
I did full lock turns in a a smooth parking lot and no sounds, vibrations or anything. It was smooth.
While driving straight and quickly turning the steering wheel back and forth it makes the squeaking noise. I've attached the video. Also can here more of a clunking noise when hitting bumps and just going straight. Bouncing the suspension makes no noise.
So end of 2024 LCAs were replaced and both front swaybar links replaced. I'm not sure if the LCA ball joints were reused of if they came with new, I didn't do the work. The boots are blue and look in good shape. Again that fixed a noise I was having then. A few months ago I replaced both front wheel bearing hub assemblies.
Its definitely not the mechanical CV joint then since its smooth through those turns.
Power Steering related maybe? I'm curious now what it may be... Sounds like a rubber bushing losing its seal or something...
That's good to know.
So I tore it back apart, remove the whole brake caliper and hung it up out of the way. Put the wheel back on, trying to locate why it has play back and forth in the 3 and 9 oclock position but not 12 and 6.
Removed wheel and tightened just rotor on, same symptom still. Remove the axle nut and axle spline is free to slide in and out a bit, still play.
Could it be the LCA ball joint. It looks like it moves a little when I grab the rotor and try moving it back n forth.
You describe the noise as rubber squeaking as well as loud clunking.
You said you recently replaced the LCAs. Did those not come with new BJs?
Try disconnecting the sway bar links and going for a drive. That noise kinda sounds like sway bar bushings.
If it's not too much trouble, try to put the gopro/camera by the left wheelwell? maybe it'll pickup the source of the sound.
(it's harder to guess what makes the sound from the cabin alone)
So turned out to be the LCA. Around a year old, from Napa and it went bad. I was able to do a warranty exchange and no labor cost since I was doing my own work luckily.
So hopefully now I'm good for many more miles, new LCAs, wheel bearings and tie rod ends. Got an alignment and feels good.
Thanks to all those for help and suggestions.
Second LCA was probably easy since you've already learned all the tricks lol
