Ignitor coil test, interesting results....
mzdfc3s
so this is an update to my ongoing problem with lean a/f reading approaching wot and open loop control. i decided that since i wasnt getting anywhere on here and the cpu wont through a cell that ill have to check everything manually. got the multimeter out and tested injectors-ok, maf-ok, then got to the ignition. both coil packs-no reading at all?? #1 high tension lead read 3.12 Kohm(this should read from 5-12 Kohm), and #3 high tension lead read 0. WTF????? how does this car still start, and run ok to a point (wot) with these readings? or do they just mean that they are functioning, but not where they need to be?? but this goes back to when i posted a few weeks ago and someone did suggest that the coils were bad, maybe this is it???????
ZenProtege said:
how exactly did you test the coils?
as instructed by the shopmanual- hooked the multimeter up to the outputs on each coil. say coil one charges cyl 1 & 3, manual says to ceck resistance connecting from the high tension lead to the boot that goes down into the cylinder head to connect to the spark plug.
Brian MP5T said:
It should be 1,4 and 2,3...
well, it was just for reference.nothing specific, but you get the idea.and i retract what i said about the high tension leads, i had them backwards and wasn't getting an accurate reading, they are both ok, but checked, re-cheacked, and double checked the coils and cant get them to read resistance at all. i even checked continuity on them and the multimeter that i had sends a 2 Kohm load through the circuit and measures the amount that doesnt come back on the other side, and both packs read 2 Kohm.which tells me that there is a short somewhere in the coils, still just a guess....im really not too knowledgable on ignitions....
Both 1,4 and 2,3 fire each revolution. It's the valve timing that sets which is what "stroke"
Just FYI.. that's why there is only one trigger wire for each coil.
Try measuring the resistance without probing through the plug wires. Just measure the resistance through the coil by itself through where the plug boot connects. See if you can get a reading that way. Then compare the reading of the two coils. If they have a much different ohm reading from eachother that's a good indication one is faulty. I would check the wires too. I think it's suppose to be around 7k or 9k ohms of resistence per foot of wire.
yeah i checked em that way too. wires read fine, one was 3.5 or so and the other about 9. and they are both within there ranges because each one is different. i cant get either coil to read and that really doesnt make any sense? the continuity test shows that there must be a major short inside them somewhere but if that were the case i dont see how they would work at all? maybe they are just burned out and start to arc under certain conditions...i really dont know what is going on??
If you read the manual it says to test 1 and 4 together, and then 2 and 3 together. What the hell is 4? I got 7.8 between 1 and 3 and then 8.3 between 2 and 3 so I think I am ok, but just wondering???
