Cmon, dosent someone know?
Or at least someone that has a scantool so that they can check.
Please guys, help...
Yeah, I know everything. First off, what are you asking? You want ignition timing? If so, which engine, specifically? and what "wheel" did you "move". Did you remove or "move" the crank pulley? Did you have the TDC alignment stop installed? Do you know what you are doing?
I moved the bottom sensor thats lockated on the front cover of the engine.
I need someone to connect a scan gauge and check what the ignition is set to on idle when the engine is warm...
Ok, I think I get it. You want to know the Timing value at idle? If I remember correctly, my `07 idles at about +12 deg (BTDC) @ ~700 rpm as displayed on the DashHawk. I'll check again to be sure though.
Thats exactly what i meanFinally someone who understands the SWEDE ;-P
Would be great if you could check...
Sorry, I'll check it this weekend. I've had the oil pan off for few days...
Confirmed. +10 deg at 700 rpm idle....
