Ignition, what numbers on idle?
X-Man
Just started my new rebuild engine, and i moved the sensor from the bottom wheel. And forgot to check what the ignition was set too.
Anyone out there who knows?
Thanx
Cmon, dosent someone know?
Or at least someone that has a scantool so that they can check.
Please guys, help...
Yeah, I know everything. First off, what are you asking? You want ignition timing? If so, which engine, specifically? and what "wheel" did you "move". Did you remove or "move" the crank pulley? Did you have the TDC alignment stop installed? Do you know what you are doing?
The thing is that Im from sweden, so theres probably a chanse i wont be translating everything correct.
Yeah i know what i m doing, when i installed my new rebulit engine i removed the sensor from the lower wheel whithout checking what the ignition was set to.
The engine runs great, i just wondered if i could get help here?
Its a Speed 6 -06
Just did a rebuild piston rods cp-e pump 3071 etc etc :-)
I moved the bottom sensor thats lockated on the front cover of the engine.
I need someone to connect a scan gauge and check what the ignition is set to on idle when the engine is warm...
Ok, I think I get it. You want to know the Timing value at idle? If I remember correctly, my `07 idles at about +12 deg (BTDC) @ ~700 rpm as displayed on the DashHawk. I'll check again to be sure though.
Thats exactly what i mean :-) Finally someone who understands the SWEDE ;-P
Would be great if you could check...
