huh???
if youre having turkey problems, the solution is NOT to expose it to a vacuum-only source (like it may be for a wastegate). you need stronger vacuum, but you usually need boost to hold the valve closed.
the brake boost is the strongest source of vacuum because its the biggest line and because of its placement in the IM. it comes out of the back, and snakes upward and toward the drivers side. there is a check valve in it so the brakes dont see boost, yes, but you need to tap the line BEFORE the check valve (to the left/passenger side). you will get a stronger vacuum, but you will still get boost to power a boost gauge, wastegate, EMS, blah blah blah.
you should invest in a vacuum block to install there so you can run lots of stuff. i think i have fittings if you need them.
rick, you already have a vacuum block. if you need 3/8" barbs (1/8NPT) for it, i think still have some i can get rid of on the cheap.
