I Want 250 Whp
Go to a hobby store, and pour 4 gallons of Nitro Methane in your tank. the ECU will map itself out, and youll probably be pretty close to 5RT-4 beating.
LOL yeah Nitro in your stock car... So what mods are on the car so far. A lot of people have blown way before they ever reached that HP level. First you have to understand that it may blow and be willing to take that risk. I would go EMS to control a/f and ignition and eliminate fuel cut, straight through exhaust to get the heat out as quickly as possible, boost controller of some kind (I'm running a mbc), relocate MAF, the list keeps going. Then you have to worry about your clutch, LSD, traction, it's not as easy as it sounds.
Tibbytomazda said:
with stock internals wht would u all suggest i do
a GT28RS, a haltech, some water:meth injection, and some good luck.
Check out my website for the appropriate parts.
depends how long you want it to last. Race gas and lots of boost will work pretty well . . . for a while. worked for me anyways.
I second this. In fact I want to say with it tuned correctly on 9PSI you should be right up there with a good FMIC. Meth would def help. I should be up there, but that's the butt dyno doing all the talking.
well i talked to jdm sam he said i coudl make 230 whp at the mos tiwth stock internals im ok with that i think that will be beating evos and stis
Really? You think 230 HP FWD is going to 'beat' 300 HP 300lb/ft TQ STi's?
At what? Fuel efficiency?
From a roll it could happen. Just not from a dig.
300whp? No dice. More like 230-240. From a roll, it would be interesting. From a stop with some good radials, it might be closer than you think.
I know, I know, the STi's are 300/300 at the crank, not the wheels. I'm just being an ass today. :mad:
I second this....from a roll of course....i've done it, still have stock internals and still praying i don't find a rod through my block one day....lol (bang)
Speed_Racer said:
+1 on the stock sti's. evo's are whole other animal.
So u have beat an STI, but not Evo?
Im running 9 psi (with the cheat cheap spring Mod), a Custom
SRI and A Samco Hotpipe. I wonder once i get my SMIC if i could
hang with SRT-4's?
no no no sir, I'm not saying I beat either. just saying there is a difference between stis and evos from a roll.
