float_6969
- 2003.5 MSP Blue #2450, 1995 Nissan 240sx, 1996 Mazda Miata
So I'm bringing this back from the dead. The oil consumption DIDN'T stop. The oil consumption is sporadic. I can run a tank of gas through it, and it won't burn a drop. Then I can re-fill and it will burn a half a quart on the next tank. Totally unpredictable. What is predictable is that the oil consumption is isolated to the #2 cylinder. A couple of months ago the car stared running poorly and the CEL came on. Checked the plugs and the #2 was so badly fouled it stopped firing. The other 3 looked fine. Replaced the plug and all is well again.
Also, the car will blow oil smoke on startup. Sometimes you can't see it. Sometimes it like a crop duster just flew by and you're surrounded by it. The oil consumption is still random. I know that it uses the most oil on decel (high engine vacuum). I discovered this because we were in the mountains and coming down off of the mountain, I was engine braking a lot. As we got to the valley, I got back on the throttle, and the exhaust blew so much oil out of it, that I couldn't see the cars behind me. It also used over a quart of oil on the trip down (I checked the oil at the top of the mountain and topped it off). When I found a spot to pull over to check the car, I thought I blew the turbo as there was oil visibly coming out of where the turbine housing and center section meet. It was also coming out from where the S pipe bolts to the turbo. But as I inspected it more closely, there was also oil coming out of the flange where the turbo meets the exhaust manifold.
So at this point, I'm thinking either a bad PCV valve (It's been replaced once already, but it was a generic from the auto parts store), bad valve stem seals, or bad piston rings. So I ordered a MSP PCV valve from Mazda an installed it. No difference. So then I removed the valve cover and modified it with baffling to keep the oil from getting sucked up into the PCV valve. No difference. At this point, I just turned over 100K miles and I figure I'm due for a timing belt. So I order a belt kit, water pump, front main seal, cam seals, and valve stem seals. I replace all of it, including the valve stem seals, which would have been a really crappy job if not for some special tools I found. Anyway. It made no difference. So I repeat the compression test. Same as last time, 190psi +/- 2psi, engine warm, throttle open, no fuel pressure.
I'm at a loss here. The oil consumption is getting worse. It's starting to use oil predictably now. I go through about 4 quarts every 3K miles. The #2 plug is looking bad again already and I would be surprised if it lasts more than a couple of months. The other 3 still look fine. If I had bad rings, wouldn't it show up on the compression test? Do I need to go buy a leak down tester? What about a worn valve stem/valve guide? Why only the #2 cylinder? Do I need to get a Millenia PCV valve? If it is through the PCV valve, I could test with a catch can, any reccomendations? This is getting really bad. I'm having to add oil almost every tank of gas (It still somewhat random in that sometimes it won't burn any oil on a tank). I've been around cars for a while, but never run into anything quite like this.
