dad of jon
- cx-5 se-l 2.2D
Hi, I was debating if I should put this under the electrics or engine section, but figured it could go in either, so put it in the welcome area instead.....
anyways, I'm at traffic lights a couple of times in the morning work commute with the fan on 2 bars blowing to the windscreen (demist) the aircon is on eco mode. The auto lights are off. The engine is still idling. So the windscreen now has no mist on it all. I press the mode button to direct warm air to the front vents to warm up my hands a bit and the I-stop comes on. Since I've noticed this the I-stop has never activated with the fan directed onto windscreen.
I wouldn't have thought blowing air on the windscreen rather than through the front vents would use up so much more power that I-stop would not activate. Maybe the designers assumed that when on windscreen setting it's important to keep the air flowing for demisting purposes and that I-stop is not appropriate in those circumstances.
Either way, If you think your I-stop doesn't active as often as you think it should, try the mode button, to change from windscreen to face.
