I might get banned for this
Yes he is. He's also getting new night glow exhaust tips. I can't wait for him to install them!!
Danny, kinda off topic, but I see that you have the rear plastic rebar behind that bumper. If you run out of things to do, I'd recommend changing it out to the 2000+ rebar. Much stronger if you get rear ended *knock on wood*
the whole theme of the car is clean and you think I'd actually go with spinners? come on peeps you know me better
Yeh, but he's still getting the night-glow, light up exhaust tips.
hello from the dead (braindead
if anyone does this mod take note the second pipe needs to come off at an angle like a Y and not a T (like in the pics), the second pipe catches jack s*** with a 90 degree connection.
I figured as much
So are we talking crazy smoke out of one side and nothing out of the other.
Looks good at the least.
At the Advance Auto Parts the other day I was there, I saw that they now have flexible exaust tubing. It has a design similar to that silver duct-work tubing you see kids stick on their arms when they pretend to be robots. It's a bit more expensive than normal tubing, and it might not have as good a flow as a normal tubing with all the flex grooves (since I really had no interest in buying any, yet at least, I didn't really examine it to see if they had a covering the inside), but as you might imagine, it's a lot easier to work with. Just bend it like Gumby where you want it to go... Might have been a little less complicated than that weld job.
they've had that forever... it's for DIY fixes if you have a pipe rust out or something
not to be the one who flames but. ur goin to have about 85 % of exhaust out of ur stock side and the rest out of the other if tht much. it still looks good but if ur not worried about power issues which u wont loose enough to be worry about. its just tht u put so much length on one side itll be un even when its cold
actually you're wrong, it's not 85%, it's 90% ;)
not 85%, it's more like 100% - hehe. the driver side tip looks brand new. the connection is getting rewelded into a "Y"
Still looks clean man. Just sae this for th first time and i hav to agree with the others looks stock clean.(first)
Document not found.
Please make sure your member name / number and file name are correct. (err code. A)
