G
Guest2019C20
The CX-9 didn't 'fail'. This 'test' isn't anywhere near real-world off-roading.
Something else I noticed in Car Question 'tests', when they tested a subaru forester, they left BOTH rear wheels on flat ground. Even so, it took many seconds for the subie to crawl up.
(The reason this is significant is because none of these AWD vehicles have an LSD (read Limited Slip Differential. The vehicles are literally 2WD when 1 tire at the front and 1 tire at the rear have traction. That means the other tires will spin freely, until the ABS is used to send power to the other wheel. If the test places 1 front tire and 1 rear tire at the 'peak/edge' of the ramp, then the other two tires have very low traction. When they 'test' outside of that setup, the test is bogus.)
ALL the cute-utes (even the new jeep compass!) use part-time clutches to feed power to the rear wheels. It's down to the programming to differentiate how the vehicles perform. For almost every buyer, there's no difference.
